fork tube caps
Discussion in 'Other Service and Maintenance' started by hog up, Jun 23, 2014.
  1. hog up
    hog up Member
    22
    13
    changing fork oil myself for the first time. scratched the chrome caps from using wrench to loosen. what do you guys recommend to use with this? is there a special wrench or something you modify for this? thanks, hog up
  2. Bodeen
    4,647
    73
    222
  3. hog up
    hog up Member
    22
    13
    thanks bodeen will pick up that tool. hog up
  4. SE6A
    SE6A Active Member
    102
    3
    I had this situation recently, a friend lent me a quality 'snap- on' adjustable 12 inch wrench, and with careful tightening, ensuring a good fit, it worked well with no scratching......but as always, if you can source the right tool for the job, it makes it far easier!
  5. gator508
    gator508 Well-Known Member
    2,790
    187
    I bought a six-point socket when I changed my fork oil. Got it at Autozone for ~ $10. Had to loosen the handlebars to be able to fit the socket on the caps.
  6. Bodeen
    4,647
    73
    222
    The tool in the link is essentially the same thing except it is short enough to fit under the bars and you can use an adjustable on it.
  7. gator508
    2,790
    187
    Now you tell me:D:D:D
    But I did like that I was able to torque it to specs.
  8. 03HD883R
    03HD883R Active Member
    167
    Using the right tools to take something apart can save time, money and aggravation. Also prevents FOD.
    If you want replacement caps, I'd go with the DBI Fork Tube Caps. I bought a set for mine and no more jacking it up to change the fork tube oil. It's got a 10mm center Allen socket.
    I've gotten lots of people ask me what it was for, and they were shocked and wondered why Harley or other manufacturers don't do that to make it easier for the end user to change the fork oil. Something that most people neglect.
