Fork Oil Weights
Discussion in 'Chassis, Suspension and Front End' started by glider., Jun 23, 2007.
  1. glider.
    glider. BOT Machine
    18
    There seems to be some confusion about fork oil weights. Here's a list of them and the associated weight of the oils. If you want to make your front end firmer, you can go to a heavier weight oil.
    One thing that should be pointed out here is that the industry standards that apply to other oils DO NOT apply to fork oil. One manufacturers fork oil of lets say 15 wt are not the same viscosity as another manufacturers 15 wt.
    ie. Bel Ray 15 wt is not the same viscosity as Screamin' eagle 15 wt.
    Fork Oil - 16oz. Type E 5wt. Type E is for "Showa" forks.Part # 99884-80
    Fork Oil - 16oz. Type B 10w. Fork Oil - See owners manual for recommended style. Part # 99880-73
    Screamin’ Eagle® Performance Fork Oil - A heavier oil (15wt) provides extra damping in performance application. Part # 99881-87 . Works well to take the dive out of the front end on breaking.
    Screamin’ Eagle® Racing Fork Oil - Designed and blended for the severe conditions on the race track (20wt). Not intended for street use.
    Part # 99909-93R
    There are also other options for tuning the forks on your bike. Bel Ray makes a host of different weight oils to do this also available in 5wt, 7wt, 10wt, 15wt, 20wt and 30wt.
    www.belray.com/consumer/productpages/hpfo.html
    Stiffness of forks is purely personal preference. A heavier fork oil will not create a stiffer fork, but it will slow down the damping response. This is good for handling, up to a point. A fork with heavier oil won't dive as quickly when you grab a handful of front brake heading into a turn. It also won't wallow as much in a fast turn. All this is good, up to a point. A fork that's too heavy provides a harsh ride and can cause a loss of traction over stutter bumps in a turn. You need to decide what's best for you. If you're happy with the way the bike handles now, then stick with factory recommended weight of fork oil which in most Harleys is a 5 wt oil.
  2. DZRyder
    DZRyder Member
    53
    Will adding 15 weight fork oil help in the bottoming out hitting adverse roadway joints, pot holes, etc.
  3. glider.
    glider. BOT Machine
    18
    10 wt will do that for you. The 15 wt is a bit stiff.
    You can also add 1/2 ounce to each fork over the recommended level if the 10 wt doesn't give quite what you are looking for.
  4. JJDH
    JJDH Active Member
    272
    Spectro type E... Works great...
  5. DZRyder
    DZRyder Member
    53
    Mr. Data, I weigh 240, i already have SE 15w, you think that will still be to stiff. A strong wind compresses the front end now.
  6. Bud White
    3,270
    3
    I was at 325 and now that i have dropped a bit of weight into the 270s now the front end is to stiff with 15wt
  7. glider.
    glider. BOT Machine
    18
    The 15 wt really does firm up the front end. I would try the 10wt first with an extra 1/2 oz in each side first.
