Frenchie
I want to explain a fly by wire issue I had traveling from Alabama to South Florida. I was about 300 miles from home when I had to slow down as as I was approaching a toll plaza I went to down shift and reduce my throttle and to my surprise the bike would not slow down below 55 miles per hour with my hand off the throttle. I had to pull into service plaza hot. I feathered the clutch and used my front brakes to slow bike down when I was lined up with fuel pumps I used the kill switch and handle bar controls to kill bike pulled in clutch and coasted to pump. I did ignition cycle reset and checked for codes and to my surprise there was no codes present. I gassed up bike and when I pulled out of plaza I had throttle control until I got to highway speed then throttle would lock and bike would not drop below 55 miles per hour. I had the ability to accelerate past 55 but every time I would to slow down it would not drop below 55 mph. I got bike home and trailered it to my bike shop. Hooked up bike to scanner and all checked out good on scanner. I removed left hand handlebar housing and inspected wires and found wires were damaged where they go over wire routing bracket on switch housing. I replaced left hand handlebar wire harness and bike now had good throttle response. I found that the cruise control will not engage until you are in third gear or higher and your speed is between 30 to 90 mph. So that is why I had throttle control at slower speeds but when bike was cruising throttle would lock due to cruise control wire shorting and the cruise indicator ligh nev
