Speed Racer
My 85 FLT doesn't want to start when it's warmed up. I crank it and smell fuel then it backfires out the exhaust, then it usually fires after that but runs like (EDIT)
It seems to fire as I let off the starter button when it does start. When I do get it started it won't rev either. I checked the carb and the accelerator pump works fine. Checked for intake leaks too. The next morning cold it fires and runs fine. Coil breaking down? Also only showing 12.2 volts at the battery at about 2500 RPM. Anybody???????? Thanks!
