FLSTF Shifting into 1st gear
Discussion in 'Softail Models' started by Purple king, Sep 1, 2009.
  1. Purple king
    Purple king Member
    12
    My wife rides a Fatboy and every once in a while when she is stopped and goes to start again she finds that the bike is not in gear after down shifting into 1st. The neutral light is not on, but it will not go until she kicks down on the shifter very hard (sometimes she has to rock the bike, or go through the gears). The rocker feels kind of slushy at the time, the bike has the extended shifter. Has anyone experienced this or have any ideas of what could be causing it? Thanks!
    Could be a clutch adjustment of the shifter forks in the trans need an adjustment. Sometimes the gears just don't mesh right but it shouldn't happen too often at all.
  3. vtbikers
    vtbikers Active Member
    174
    What year? Harley did have a problem with shifter forks, but it's been quite awhile ago.
  4. Purple king
    Purple king Member
    12
    Thanks glider & vtbikers for responding, I will look into that. The bike is a 2004
