Boilertrain
My '98 883 has a 1200 kit in it. I am experiencing a lot of valve train noise. Are there steps I can take to reduce it?
Check all the engine mounts for torque.Especially the upper mount.With the combination of noise and vibration the primary chain tension is suspect also.A loose pipe/heat shield can do the same thing.Sounds like you should "go over" the bike slowly and inspect everything.Let me know what you find.Thanks for all of the feedback. Unfortunately I have now developed a severe vibration. I noticed that at idle when warming up that the bike vibrates more than normal. I also notice as the RPMs increase so does the vibration. Any thoughts on what would cause this? It is getting worse the more I ride. I am contemplating replacing the tappets. Not completely sure that is the problem, but I am not too sure what to do next.
Cheers to all
