Finned HeadBolt Bridge / Saddle Heat Shields
Discussion in 'Touring Models' started by Bud White, Feb 11, 2009.
  1. Bud White
    3,270
    Both were a quickie install with not a lot of pics so i figured might as well combine them
    Here is what it looks like stock
    [​IMG]
    Install the head bolt covers with the caps with 2 set screws in each tighten the set screws into the caps little tricky to tighten but can be down
    [​IMG]
    Then install the bridge 2 screws go down though it if you install it with the allen wrench they sent you good luck .. I found it easiest to use a Allen Wrench on a 3/8 socket bit it was short enough to fit in there finger tighten then use the wrench they sent to tighten the rest of the way
    [​IMG]
    Now on to the saddleshields
    You have to install the nuts into the frame plate they send them to you as a crush nut where you install them .. pretty easy on the 08's pre 08 lot more involved by the instructions ..
    [​IMG]
    The side Covers top screws are little hard to tighten but can be done the right side is the worst as you basically have to rub the cylinder fins the whole time unless you got a tiny hand
    Now that i got them installed i notice when i add a oil gauge i will have to try to modify the shield to fit
    [​IMG]
    [​IMG]
  2. Bud White
    3,270
    Thanks Hobbit
  3. Bud White
    3,270
    Kurys go under the seat can't say on the others
  4. NEWHD74FAN
    8,191
    98
    19
    Good post Bud, the bridges look good, I recently installed them on my Sporty as well. Didn't you have heat shields on your bike before...I heard late model tourers like the Ultras got pretty hot, but does the Road King also? :)
  5. Bud White
    3,270
    I didn't have them before but yes it got hot .. i think if i was one of them people that ride in shorts i would have sold it first time i was in traffic i was roasting in jeans on stop and go even when not stop and go it gets hot enough even passanger complains .. but most i have done this winter is to combat that
  6. steve299
    steve299 Active Member
    157
    Nice job, I was thinking about putting them on my sportster, but was worried about if they could cause any problems. Have not seen them on many bikes around here. Youes look really good.
  7. NEWHD74FAN
    8,191
    98
    19
    On my older model 2004 XL1200R carbureted, does not have "-par-broiled leg syndrome"; however I have heard the newer models '07 up run hotter due to leaner EPA mandated lean A/F mixture when fuel injection was introduced...
  8. jimharvey1
    jimharvey1 Junior Member
    469
    9
    Ok...I just finished the installation of the Mid-Frame Air Deflectors (58022-07) on my '07 FLHTCU. The illustration (fig 3. fastener locations) is a bit confusing when you first look at it. The only way you would see it as illustrated would be if you had the motor removed from the frame. I really have three suggestions for anyone planning on installing the kit.
    1. Before you leave the dealership (or at your local hardware store) pick up a 0.25-20 x .750 inch HEX HEAD bolt to replace the button-head screw provided in the kit (fig. 4, item 9 or Fig 3, location 1) to install on the right front attachment point. With the 96" motor, it is impossible to get an allen wrench behind the rocker box cover to tighten the button head screw provided in the kit! (see attached pic)
    2. When installing the speed nuts (fig 4 item 2) reverse them on the strap so they slide on to the strap from the rear. It makes alignment of the strap so much easier.
    3. Have a magnetic tool handy because you will undoubtedly drop the strap with the speed nuts attached and the U-clip for the rear of the left deflector several times during the install. It keeps the explicitives from reverberating from your garage and offending your neighbors on a Sunday morning.
    :newsmile055:
    Other than those little glitches it was a seemingly painless install and I am looking forward to a summer where I am not listening to the fat on the back of my thighs sizzling from the heat at a stop light.
  9. Bud White
    3,270
    you can get the allen wrench in there its just tight
