Final drive belt deflection spec
Discussion in 'Other Service and Maintenance' started by khahn, May 21, 2014.
  1. khahn
    khahn Member
    20
    Just picked up a 2014 Fat Bob, love the bike, but the dealer prep left something to be desired. Anyway, as I was going over the bike to make sure every thing was kosher, I checked to belt tension using my handy dandy HD belt tension checking tool. According to my 2013 service manual, the belt should deflect 1/4 to 5/16 of an inch with 10 lbs pressure applied. Is this still a valid spec for the 2014's? Mine deflected almost a full inch....pretty sure that's too loose.
  2. Bodeen
    4,643
    73
    221
    Not sure what the '14's spec. is but I would check my owners manual.....Then I would order a service manual. Both are invaluable IMO.
  3. dolt
    dolt Senior Member
    2,172
    103
    333
    I don't use a tool. If I can rotate the belt to a 45* angle with my thumb and forefinger, I call it good. If it rotates more than 45*; too loose. If it won't rotate 45*;too tight. Caveman style but it has worked for me for years.:D
    I would take Bodeen's advice however and pick up the Harley SM for your model; best tool in your tool box.
  4. khahn
    khahn Member
    20
    I agree, I have a 2013 dyna service manual that is probably valid for my 2014. As far as the owners manual, I just noticed they gave me an owners manual for a 2013, guess I'll go back and ask for a 2014 manual.
