Fat Boy Headlight Adjustment
Discussion in 'Softail Models' started by G Nick, Apr 18, 2010.
  1. G Nick
    G Nick New Member
    Hello Everyone. I'm new here. I recently bought a 1998 Fat Boy Anniversary with 11K miles on it. The headlight is really poor, and it needs adjustment at the very least. Does anyone know how to go about the adjustment?
  2. Hoople
    Hoople Account Removed
    7,198
    34
    Shine your low beam headlight against a wall 25 feet away. Measure the height of the light cut off being projected onto the wall. It should be 2" lower than the headlight filament height.
    Meaning headlight cutoff should drop 2" per 25feet of distance.
  3. glider
    50
  4. G Nick
    G Nick New Member
    Thanks for the info, but where is the adjustment "screw" located??
  5. Hoople
    7,198
    34
    Think the data was coming in while you were typing. Glider has you covered.
  6. glider
    50
    G Nick
    I would strongly suggest getting the factory HD repair manual for your bike and it will show you how to do many things.
  7. cossak
    cossak Member
    93
    I can recommend the 80/100 osram bulb. It fits in the reflector with only a little tab that needs to be filed off, about 1/16" then it drops right in socket perfectly. It draws a little over 8 amps on high but with a 20 amp fuse and nothing else running off that wire and fuse it has not be a problem. Only draws 6 amps in low and I usually ride with it on low in daylight. Big difference! at night, great detail visible on road and sides of road. HD should use this bulb as it's standard equipment.
  8. Hoople
    7,198
    34
    It's great you listed the current loads of each filament. Good info Tks.
