very common, I think it also depends on the roads you travel, I live on a graval road ,so it is expected in my case , I do a weld, add some extra metal were the factory break (bend is) that is where they crack 90% of the time . they are made of some thin gauge metal. Ive found there is really no need to check unless you do ride on bad roads ,then you just want to go ahead and do some welding of some extra metal at the point where the bend is. If they are cracked you will know, Your faring will have alot more vibration then usual. I have talked with my service writer at my dealership about this issue and they just replace with the same ones there is no upgraded version as I am told, this riding season alone I fixed or did my upgrade to 7 or 8 bikes in my area , out here most if not all live on graval roads or travel down them at some point on any given day. So its a common issue.the brackets are 26 ga at best most likly 28 ga.I use 22 ga make 1''x1'' angle clips and weld them in seems to work have had no issues at all.
