I hope this is the correct forum to post this, if not I apologize.
'02 Heritage
This problem has been going on for a while. It started after the bike was not being ridden for some time, it was stored with the alarm enabled and went into storage mode. When I went to go for a ride, I set the alarm off (no siren) and had to use the manual disarm because the fob would not work. Since then I have not been able to enable the alarm with the fob (I have 2 of them and neither work). I have also noticed that I can not even get into the manual disarm mode either (alarm is not enabled). The turn signals work fine.
The things I have tried so far are:
-Replace the Fob battery in both fobs
-Re-syncing the fobs using the procedure in the owners manual which appears to work because I DO receive a confirmation.
It seems that the receiver shuts down after being in the programming mode.
Anyone have any thoughts?
Thanks
-BG
'02 Heritage
Thanks
-BG
