Exhaust Smoke?
Discussion in 'General Harley Davidson Topic' started by 5dollars, Mar 28, 2014.
  1. 5dollars
    5dollars Member
    Ok, turned the bike on to take it in for a checkup. Before I could get my helmet on I noticed smoke coming from the exhaust pipe where it is connected to the motor...any ideas???
  2. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Are you saying it was coming OFF from around the pipe or where it connects into the motor.
    IF off the pipe, it could have an oil leak from a valve-cover gasket OR a Loose leaking Exhaust Flange and gasket. (smoke should mean Oil)
  3. TQuentin1
    4,737
    142
    Is your valve cover leaking oil down onto the header? This gets seriously hot, and oil will smoke quickly if you get some on the pipe near the heads.
    If not that, could something else have gotten on the pipe?
    If you are getting smoke at the head, but not at the end of the exhaust pipe, then I don't think you have smoke in the exhaust.
    Cheers,
  4. 5dollars
    5dollars Member
    I do not see any oil or buildup in the area, it appeared to be blue smoke with a funky smell. I shut it down and waited for about 30 seconds before I started it up again. As soon as I saw the smoke again I shut it down. Harley is coming to pick up tomorrow, they did not want me to drive it up there...
  5. gator508
    gator508 Well-Known Member
    2,788
    187
    A good idea on Harley's part since it's still under warranty...right. Lets us know how Harley handles it. Thanks!
  6. 5dollars
    5dollars Member
    Go figure, when you take your car to the mechanic the trouble stops. Well its the same for motorcycles:newsmile108:. Harley could not find anything wrong with the bike...
  7. 34thestickupkid
    34thestickupkid Active Member
    217
    I knew you was gonna come back and say that,,I hate when that Happens
  8. lvlao
    lvlao New Member
    You check if it stop after 2 - 3 minutes? If the muffler are cold it can be only h2o vapor
  9. Jack Klarich
    This may sound dumb, is the oil tank over full? Do you have upgraded air cleaner?
  10. BUBBIE
    4,974
    125
    There several ways Oil/Contaminants can get onto the head pipe. Jack noted one is the air box filter.Checking the oil dipstick and allowing it to Drip onto the pipe (common)
    Another is leaking down from a valve cover gasket. That must have been eliminated by the HD shop.
    The Other:
    Some times Wax or Cleaner can be wiped on the pipe and Smoke-Off when started.
    NO oil under bike is a good sign of Not much of a problem but from human workings.
    Good you have NO problems but still wondering what caused the Smoke in the first place.(aren't you?) Me too....:s
