exhaust recomendations
Discussion in 'Softail Models' started by 98fat, Dec 22, 2009.
  1. 98fat
    98fat Active Member
    136
    I know this has been covered many times before, but would like a recomendation for a better exhaust system for low end performance. I have read alot of the other posts on this issue. I have a 98 fatboy with a Dave Mackie dm500 cam (bolt in) and Vance and Hines big shot stagger exhaust (no baffles). Jetted CV carb. The thing suffers from lack luster performance until the cam kicks in at about 3800 rpm. Looking for low end torque. I could order baffles for the Vance system but would rather look at another system. Thinking about a Vance Pro pipe (chrome).
    Thoughts.
  2. mmowrey
    mmowrey Member
    10
    The D&D fat cat 2 into 1 was the best money I spent on my bike by far, felt like a different ride after the install. Lots of bottom end and i can actually feel the bike pulling in 6th gear.
  3. hogrotten
    hogrotten Junior Member
    642
    5
    +2, with the exception I'm running the samson caliber 2-1's. Also as mentioned the best money I've spent on my bike.
  4. dino769
    dino769 Member
    5
    98fat,
    I'm running a 2 into 1 Vance and Hines Pro Pipe HS on my 1994 Softail. I totally love the performace with this pipe. It has great torque and has a good sound also. I'm running the competition baffle in it also. V/H has a new Pro Pipe BS, which is suppose to eliminate the slight gold bluing in the center of the baffle. I was running a Thunderheader before the V/H Pro pipe. Got rid of the TH becuse it kept buring ignition modules as the rear pipe wraps the cone on the Softtail. Not to mention the bluing of the pipes out of the cylinders without any great covers avaliable. The Pro Pipe is worth the money, Chrome looks great and hold up. I would reccomend it as I have been running it on my Softtail (FXSTC) for years.
  5. UGSBUE
    UGSBUE Member
    10
    since we're talking pipes...i'm looking at the V&H Big Radius for my 08 FXSTC...
    any experience/thoughts appreciated - everything is OEM at the present time...
    thank you
  6. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,823
    133
    208
    Hey Hobbit, you need more black on that bike. :s
  7. Joyflyin
    5,823
    133
    208
    It does rate very high in the cool factor though. And more importantly, it looks scary fast. I guess my bike could look scary fast except I ride it like a grandma. :newsmile011::laugh
  8. UGSBUE
    UGSBUE Member
    10
    Thanks Hobbit,
    When you say "fueler" i assume you mean fuel-management (correct?). And yes, i will do a full stage-I type upgrade including air-in, fuel-manage, and exhaust-out...
    Thank you for the feedback!
  9. 98fat
    98fat Active Member
    136
    Thanks everyone, I have looked at the PRO Pipe HS but didn't want the blue problem. The BP pipe isn't made for a 98 (old bike I guess). I am looking at the Big Radius 2 to 1, has a removable baffle and is "blueproof" for the entire length, and has similiar performance according to the Vance people. I would like to hear one in person before buying. Curious if the D and D has a problem with the blues.
  10. chopperfreak
    chopperfreak New Member
    3
    i have a 2002 nightrain with the following mods. S&S direct drive gear kit.(replaces cam chain tensioners) 510 grind cams. Adjustable pushrods...(to accomodate the cams) High flow air filter. Thundermax ECM and closed loop system with the O2 ports. Black 2 into 1 D&D fat cat exhaust.
    The bike pulls good and sounds decent. i used to have samson shortys on my bike and it sounded LOUD AND OBNOXIOUS but i wasnt getting enough pony's. So swapped the stuff out, re-mapped the ECM and rode it. Definite difference in torque and horses. still pulls hard 100 mph and has good torque range. Gonna try to post some pics, but im new...so may not work. "the Jewish Indian" DSC00002.jpg
