I ride a 2000 rd king fuel injected. Recently have been hearing a chirp/chchch sound coming from the front of the motor while riding. I checked once and discovered that the nuts on the stud mounts had vibrated a little loose, tightened them up and almost all the noise disappeared. This has happened more than once. So do I
1. Loosen the nuts up put on loctite and re tighten?,
2. Replace the gasket and get the rust off of the stud mounts? and
3. Since I can't find it anywhere, what would be the torque on those nuts?
Any suggestions and thank you in advance for all the good information I know I will find and receive on the forum
