evo
Discussion in 'Touring Models' started by tdj45, Apr 13, 2010.
  1. tdj45
    tdj45 Member
    71
    the newer twin cam engines have cam tensioners but what is the difference with earlier EVO engines
  2. TQuentin1
    4,737
    142
  3. Jack Klarich
    Oil jets to cool the pistons, internall oil pump, longer stroke, improvement on the Evo, tho nothing wrong with the Evo motor JMO
  4. Bud White
    3,270
    less vibration to esp on a softail the twin cam that is ..
  5. 98fat
    98fat Active Member
    136
    Wouldn't own a twinkie.....:D
  6. glider
    What HYD tensioner are you referring to with the gear drives???
  7. glider
    OK Gotcha. I thought you were referring to tensioners in a gear drive setup.:D
