This is on a 1999 Heritage. When I start the bike it usually takes one or two cranks for it to fire.......but sometimes 5 or 6.......when it does fire it starts slowly and then builds up to full idle. Thats the problem, it doesnt matter if the bike is cold or has been ridden all day it still seems to start the same. It doesnt just hit and go to full idle.....even when I choke it when it is cold. I have checked the timing and even replaced the cam position sensor because it had melted and run down into the nose cone. Ohmed out the coil, which checked out fine, also check spark between plugs and wires, which are new. Checked battery, coil and voltage regulator connections. Carb jetting is a 45 slow and a 190 main, also checked air/fuel mixture. I checked for leaks around the carb and intake seals. Checked out the VOES, the hoses seem to be in good shape and it seems to be working correctly. What about the carb.....I bought the bike used and besides knowing the sizes of the jets in the carb, who knows what mix and match of a jet kit that is in it........what about a good cleaning, fresh seals and a new jet kit........what about bad compression or a valve that is not sealing??????? Just some thoughts.........give me some ideas........opinions
