Vibratinharley
Junior Member
I recently had to replace left side engine crank seal due to oil leaking past and overfilling primary case. Oil leaking past the check valve into engine and I think pressure from excess oil in engine where it doesn't belong blew out seal. NOW, the base gasket on rear cylinder started to leak. Can the excess oil when engine sumps ( I think thats what its called?) cause this to happen?
