A week ago I noticed that my 2007 RK Stdr. with the Thunder-Max ECM "auto tune module" was , on the speedo, registering 15-20 MPH LESS that actual. Also, the little green 6th gear light would not come on when it was in 6th gear.
 The codes were: U1016, U1300.
 I called the Service Manager at my Dothan, Al., HD and Keith told me it was probably the ECM. I had just spoken with the guys at TM and they said that they had not heard of those codes associated with that problem OR on a R King.
Keith said that they would replace the Thunder-Max with my HD ECM, ride it and see what the story was from there.
Today I replaced the TM unit and the O2 sensors with the OEM ECM and sensors.
Problem solved.
 I am sending the unit back to TM with a letter. Will see how this turns out.
Morpheus
Speedo Cal:
This setting is a calibration value, which differs in relation to certain years and/or models
of motorcycles. Note that an incorrect speedometer calibration can also affect other
electronic accessory functions. Check the Speedo Cal for your year and model
motorcycle.
This step must be performed before attempting to ride the motorcycle for the
first time. Zippers cannot be held responsible for an inaccurate speedometer
calibration if this step is not followed or neglected. Traffic violations may
result if your speedometer does not match your local traffic authority’s radar
gun
The entry can be from 1 to 99,999. At this time, the known base numbers are as follows:
2004-2005 40960
Dyna® 2006-2008 45900
CVO 2008 42450
2001-2003 4352
Softail® 2004-2006 40960
2007 - 2008 42450
2002 4352
2003 20480
2004-2006 40960
42450
Touring
2007 (16”)
2007 (17”) 42000
XL 883 2007 - 2008 48400
XL 1200 2007 - 2008 46000
Final Drive Ratio:
A setting for “Final Drive Ratio” is only needed on 2007 motorcycles with a 6th Gear
Indicator light. The default value that should be used for a 2007 motorcycle is 87.
Please note that this value is merely a compensation factor for the calibration needed to
activate the light, not the actual Final Drive Ratio of the motorcycle. Please disregard
this function if you do not have a 6th gear indicator lamp.
Dyna® Model motorcycles, use a value of 84 for this setting to illuminate the light.
Gear 6 MIN TPS:
The smallest value of throttle position that will allow 6th gear display. This function is
only used on motorcycles equipped with OEM 6 speed transmissions and a 6th gear
indicator light on the instrument cluster. If your application does not have a 6th gear
indicator light, set the value to 0.
The default value bikes equipped with this feature is 40. For any reason, if your 6th
gear indicator light is inoperable, please confirm that you have firmware version 4.3 or
later. Also confirm that the value in the 6th gear min TPS is 40. If not, enter this value
and write it to the module.
All this is in the instructions that come with the ecm. I can't believe if you talked to Randy Dull at Zippers that he wouldn't have had you check those settings and your firmware version before sending it back.
