I have a 1992 Dyna custom when the engine gets up to normal operating temperature the motor will smoke at idle. It does not smoke when cold and I have not been able to detect it smoking when I am moving only at idle. The smoke lookes to be more gray than blue. I have an oil cooler on the bike. Anyone have any ideas as to what the problem might be?
Being a 92 and you didn't mention the miles on it, I would do a compression test and if that doesn't give you answers, try a leak down test. You'll find them both in the self help forum . Chances are you have worn rings or valve seals of maybe even an damaged oil ring in one cylinder. http://www.hdtimeline.com/harley_da...ues/1026-how_to_check_engine_compression.html http://www.hdtimeline.com/harley_davidson_engine_related_issues/1378-engine_leak_down_testing.html
