sincityharley
Im doing a top end rebuild on a 2002 Heritage Softail EFI. Im going to start putting it back together tomorrow. I was just wondering if I am supposed to be using any gasket sealant with the new gaskets that I am going to use?
I agree with Brian and Iceman although I deviate sometimes if it's an area or part that is hard to hold the gasket in place during assembly. A THIN gasket seal adhesive works good here, OR on a surface that has been scratched up and doesn't seat the gasket well.
Don't use any of the thick goop gasket stuff though (like we all did when I was a kid, during the last Ice Age) That stuff is a mess and I have seen them leak even with it used.
I heard a lot of folks talking about their HD Oil Cooler adaptor leaking, not sure what the problem was but some did leak. When I put mine on I used the Permatex thin gasket seal adhesive on it.
It's like a very thin coat on the part and the gasket and then you wait on it to get slightly tacky before assembly. Worked great on holding the thick heavy gasket in place while I put the adapter on. Anyhow my Oil Cooler never leaked a drop, not even any residue at all. Anyhow that's my 2 cents worth.
