O ole1 New Member Feb 27, 2015 #1 2004 sportster 1200 custom . when i get on gas engine dies .downshifting dont restart but hitting starter button it starts right up. if it stayed not running i could probally figure it out but,? anyhelp would be aprec....ated
Jeff Klarich Experienced Member Contributor Feb 27, 2015 #2 A little more info might help. Any mods? or bone stock. Is this a recent issue?
fin_676 Experienced Member Staff member Moderator Contributor Feb 28, 2015 #3 Start with the basic stuff of checking the battery cable connections at both ends of the cables ensure they are clean and tight Brian
0 03ultra45385 Active Member Mar 7, 2015 #4 I would check fuel flow or pressure depending on carb/FI. You might try siphoning some gas from the bottom of the gas tank, look for debris or tank lining. Last edited by a moderator: Mar 11, 2015
