hi all,
I have a 2005 FLTRI that doesn't like to idle once it's warmed up. Here's the particulars:
Idle is right about 1050 rpm once warmed up.
It will intermittently drop to about 400 rpm, sometimes will recover, usually will die.
Runs fine once it's over about 1200 rpm.
If I hold the throttle at about 1200 rpm, it will run fine.
SE high flow A/C.
V&H slip-ons.
V&H FuelPak.
My thought was that it might be one particular cylinder that's causing the issue. Here's the odd part. If I pull a plug wire, either plug wire, doesn't matter which, idle drops to about 900 rpm and it doesn't miss a beat. Put the plug wire back on, idle pops back up to about 1050 rpm and the stumble comes back.
I'm not sure where to go from here (other than to a real mechanic). It acts like it's starved for fuel at idle. I thought maybe one of the injectors was cutting out once it got warm but since pulling one plug wire should have isolated one injector or the other didn't work, I'm not sure.
Any suggestions are welcome.
Thanks,
Mark B
SE high flow A/C.
V&H slip-ons.
V&H FuelPak.
Thanks,
Mark B
