electrical problems
Discussion in 'Touring Models' started by maddenj, Jul 30, 2010.
  1. maddenj
    maddenj New Member
    question:
    will a bad voltage regulator / stator make the bike backfire and sputter?
    the bike is acting like is not getting enough fuel.
  2. ultrat
    ultrat Senior Member Contributor
    1,315
    not good spark or erratic spark,,,yes i believe so..low voltage.causes problems...+ welcome..
  3. Jack Klarich
    Yep, Ultrat has you covered, a weak signal to the ignition will do that and more, check the battery first:s
  4. maddenj
    maddenj New Member
    just put in a new battery
  5. TQuentin1
    4,737
    142
