ooheritage
hello to all, hope you had a great weekend. I have had a bit of an issue with my scoot, this is what it does, the speedometer fluctuates then goes to zero, my didital for my odometer flashes rapidly and or goes completely out, it sounds like it is running on one cylinder, and when I give it gas the lights dim, when I let off the lights get bright again. the engine light comes on then if I'm lucky it like resets itself and I can run normal sometimes for 200miles or more sometimes for about 3 secounds. We checked the plugs the coil wires, I replaced the ignition controll module, the battery is good and the stator seems to be keeping it charged, the wires to the starter are tight and we try to check all wires for kinks and bared spots all connections seem to be good. I'm leaning toward the kill switch, or the ignition switch. we also checked the coil and the proper resitence is there, any helpful tips would be greatly appreciated. 2000 heritage softail cassic (carburated) also I checked to see if there were any codes and there was'nt.
