Sometimes when I turn the ignition switch on and the engine light goes out, I hit the starter button and everything goes dead. then it resets and when you sit the starter button it goes dead again. the other day when this happened I turned the ignition switch off and then back on and the engine started cranking over. I have changed out the starter relay and it didn't help. This is an intermittent problem as it doesn't do it all the time. The shop can't find out what's wrong because it won't ever mess up or occur when I'm there. Anyone have any suggestions as to what is causing this, your help would greatly be appreciated.:small3d023:
