Electrical Issue - Kuryakyn Lights
Discussion in 'Electrical' started by Bosbury1, Sep 20, 2008.
  1. Bosbury1
    Bosbury1 Active Member
    138
    Installed Kuryakyn LED lights front and back along with the Tombstone light. Purchased the Turn Brake module and security/load equalizer and regular equalizer. The whole thing worked great for about a week and the turn brake went out replaced it out along with a new load equalizer then every time i hit the brakes or use the turn signals the security light goes on. Today replaced out the security/load equalizer same problem. Basically, all parts have been changed but still the light goes on. Any Suggestions? Does a code need to be cleared?
    50
    If it is a constant light after start up , it is a current fault and needs attention. If it goes out after a few seconds, it's a historic code and will take care of itself after 50 start/run cycles of at least 30 seconds each.
  3. Bosbury1
    138
    Alright. Thanks
