T tdward New Member Sep 1, 2014 #1 What would cause headlights, auxiliary lights and running lights to shut down all at once
gusotto Junior Member Sep 1, 2014 #2 Power supply (fuse) is my 1st thought. Always check to see if you have needed power and if not, trouble-shoot the path of supply.
R Rydit Member Sep 2, 2014 #3 gotta be relay or circuit breaker in there somewhere. my '10 has a "high current relay" that will cause the same symptoms.
bravehart Member Sep 2, 2014 #5 if you check your fuse and it is good then check out the lighting relay, they seldom go bad but it does happen, I know, long ride home in the dark they don't cost much so I carry a spare one now. mine was on a 2010FLHTC
