Earth fault on my Sporty
Discussion in 'Sportster Models' started by stamford74, Jun 30, 2011.
  1. stamford74
    stamford74 Member
    8
    I've got a 2001 XL1200S, Last year I kept getting just a click when I pressed the starter button I found the live strap between Battery & starter motor had broke, I replaced this and all was Ok, I now have the same click, I've checked the same strap & it seems OK I've checked the Neutral Strap, that seems OK, If I charge the battery I just get a louder stronger Click,
    I've found that if I keep touching the starter button or just feathering it then every now and then there will be no click but the motor will spin & start,
    Once the motor is running then everything in the world is fine, turn it off & we are back to clicking,
  2. HDDon
    5,562
    133
    236
    I'm sure others will have some more ideas but I would make sure that all of the connections were clean and tight. I would also replace the starter relay (cheap) to see if that takes care of the problem.
  3. fin_676
    5,788
    153
    287
    If you are getting a click at the starter it would tend to indicate that the starter button and relay are ok and that the suspect areas would be the main cables to the battery or the starter solenoid
    it is not uncommon for the earth strap and main battery strap to corrode internally and not carry sufficient load for starting
