You will be glad you did. Make sure the tuner is really tuning and not just loading and tweaking a "map". BTW, it's not "beating the crap" our of your bike. The tuner has to tune partial and wide open throttle which will require WOT pulls. It should take a couple of hours allowing for cool down time and several WOT pulls to complete the tune as the configuration is not radical; only real change from the last dyno is the addition of the new cam so the tuner should be able to dial it in pretty quick.
A more radical configuration with increased displacement, ported heads, new exhaust, high compression, larger throttle body, .600"+ lift cans, etc. could easily take 4 hours minimum and as many as 20-30 pulls on the dyno.
