I hope im in the right section here
have a 97 EGlide 43K for miles only mods are Carb st1 kit Airfilter and VH mufflers EV 13 cam (because the old one wore a lob)
here is the issue i noticed yesterday for the first time took it on a interstate rdie cruiseing about 70mph pulled off for gas and heard a clicking sound pulled clutch and it stopped but as i was costing to a stop it felt like some one was putting on the brakes also noticed that Down shifting was a Bear really had to mash on the leffer to get it to down shift
pulled into a station and checked everything (brakes clutch play )nothing wrong
got gas and took off No noise tranny shifted fine about 25 miles down the road pulled into a rest area and had the Noise come back and again quit when clutch was pulled in think its coming from the right side
all the time the motor was running great only thing was that it was useing more gas than it used to but have not checked it since the instalation of the Cam so not real concerned (used to get about 45 but was done to 35 or so)
Decided not to continue the trip (was about half way there) tuned around at the next interchange and headed home again pulled of fthe road and noticed the the clicking noise as i was parking noticed that if you let the clutch out you would hear a noise like something was loose and you had to take up slack (again Real Hard to down shift ) had supper and filled with gas and did not hear the noise then when it cooled down got home OK but when i pulled up to garage notised a pool of BLACK OIL lear from under the primary (again was hard to down shift) in 08 had all the seals in the clutch area changed along with O rings and gaskets because it was leaking in this area Found Bad seals and spacer collar had DEEP grove
Tanny fluid is Red line and Just had changed oil in the motor before this trip
last year when it leaked you could see the color of the oil what is so Strange is how BLACK this is like something is Wearing BAD any Ideas besides trading it in on a new one hate to this runs so good and is all PAID for
Thanks
Thanks
