does any one know what ppu 78367 stands for?
Discussion in 'Sportster Models' started by rick97roadking, Jul 11, 2011.
  1. rick97roadking
    rick97roadking New Member
    that is what comes up when i check my codes on my 2003 883 d01 through d10 are clear then this comes up.ppu 78367..
    my problem i am having is the bike will randomly die..no spark...short rides long rides sometimes i can go days without a problem...
    does it stand for pulses pick up?
  2. JBC2565
    JBC2565 Junior Member
    582
  3. Hoople
    Hoople Account Removed
    7,198
    34
    My guess would be it either stands for the Speedometer application calibration number or the speedo itself. (short part number maybe)
    I am sure it does not stand for pulses pick up. Firmware diags are not that smart. I don't have a service manual for a 2003 but for starters I would look at whatever triggers the coil. Either a hall cam sensor or reluctance crank sensor. Something along those lines.
    You did not give much info except that the bike dies. Your problem can be caused by a few unrelated items other than ignition. (breakers, ignition switch etc)
  4. glider
