dented battery
Discussion in 'Other Service and Maintenance' started by flyin64, Sep 15, 2011.
  1. flyin64
    flyin64 Member
    38
    is this dent too bad to use this battery?
    mr clumsy dropped it. its opposite the neg terminal
    thanks in advance
    mark
  2. R_W_B
    R_W_B Senior Member
    2,425
    23
    Ummm that's kinda risky. First off you may have damaged the integrity of the case which could lead to a leak. But even more so you may have damaged the interior plates which could lead to all kinds of problems either immediate or down the road.
  3. Jack Klarich
    I would not chance it, like Dave said you may have internal damage, this would leave you stranded or worse a shorted battery can explode
  4. glider
    50
    Agree on both counts. Replace it to be safe. Have you ever seen what the acid can do to a bike? Not a pretty site at all.
  5. kemo
    kemo R.I.P
    1,690
    5
    You betcha, replace it.
    Ken
  6. Dswartz
    Dswartz Active Member
    366
    4
    Like Glider said the battery acid can be nasty. When I purchased my bike the previous owner did not properly maintain the battery and it had leaked acid all over the tray. This of course led to rust and all sorts of other problems. I had to spend some time last winter stripping and refinishing the tray and a few other things. Not fun, do yourself a favor and get a new battery. It's really not worth the risk.
  7. Webbtron
    Webbtron Banned
    583
    Doesn't look that bad to me but it might be a different story if it was my bike. But if it fits in the battery box seems like it would never move again.
  8. fin_676
    5,789
    153
    288
    If it were mine i would replace it in the bike but if the battery still held a charge i would keep it for the times i need a 12v power source around the shed
  9. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Another vote for replace...acid fumes can be explosive, if there's a crack. That would be much worse than fixing acid corrosion...
  10. biscuit
    biscuit Junior Member
    592
    That's a great idea.I have a couple of old batteries that are connected to my 'c tek' chargers and they are perfect to run my 12v compressor when i check tyre pressures on 3 bikes and 4 cars.I've long given up using foot or hand pumps---
