ok,,the 97 fuel injected road king is dead,,no power anywhere,,checked battery, it's good checked regular fuse block ,,all good,,are there other fuses or circuit breakers I should be testing?
You have a main breaker but they will usually only open under heat or a load above the rated amps or a combination of both. I would check the battery connections themselves. Insure that both ends of both cables are removed and wire brushed then replaced and tightened up enough for a good contact. This is usually the cause of the problem when this happens.
Thanks,,i've Already Cleaned And Re Connected The Terminals..do You Know Where The Main Breaker Is Located?
Not absolutely sure on the 97 but look under the right side cover. Also have you cleaned BOTH ends of BOTH cables?
