Cylinder problem
Discussion in 'Engine, Fuel and Exhaust' started by Wallsch, May 10, 2013.
  1. Wallsch
    Wallsch New Member
    Hello, My bike is a 95 road king. I think one of the Cylinders is not running. Also when I give it throttle it backfires. And it is spuddering.
  2. HDDon
    5,542
    133
    229
    Have you checked the spark plugs? Are the spark plug wires seated on the plugs and into the coil?
  3. Jack Klarich
    How many miles? Have you done a compression test?
  4. Slo-Ryd
    Slo-Ryd Junior Member Contributor
    527
    23
    Have you changed anything recently or done any work on the bike or did this just start happening out of the blue?
    Also, is it stock or are you running an aftermarket ignition?
    Does it sputter and backfire while sitting still and revving it or only under load while driving?
    Tell us a little more about how and when it started behaving like this and hopefully it'll help point you in a more specific area to check as well. If it's coming out of winter storage with stale fuel the diagnosis will be different than if it was running perfect and "I washed it and it started running funny". ;-)
    [​IMG]
