Posted by "Fin 676"...
Mikuni HSR is a direct replacement for the cv carb however it needs a wee adapter plate to allow fitting of air cleaners for the CV just did a quick search and found this
Mikuni HSR Air Box Adapter
However if you get one of the easy kits then it comes with the adapter in it
You can use stock choke cable stock throttle and idle cables has a vacuum take off for the voes and works with any stock air cleaner or air cleaner setup for the stock CV with the adapter.
