Cruise Control....Have a Question
Discussion in 'Electrical' started by kman96ultra, Jan 7, 2012.
  1. kman96ultra
    kman96ultra Member
    38
    I have a question with the cruise control on my 96 uc/eg.can it be used to bump the idle up when warming the bike up in morning?
  2. HDDon
    5,560
    133
    236
    I don't know about the earlier models but I don't think mine will lock in unless the bike is in gear. When I get down to the shop I'll give it a try.
  3. kman96ultra
    kman96ultra Member
    38
    Thanks Alot!!!!!
  4. HDDon
    5,560
    133
    236
    And won't stay locked in much above 90.:newsmile058:
  5. rhino 2
    rhino 2 Active Member
    182
    A throttle lock will work at any speed for what you want to do, And there not expensive at all.
  6. HDDon
    5,560
    133
    236
    Your '96 has a carb right? If so you have a choke/primer pull knob and this will have the engine idleing high if it is working correctly.
  7. Jack Klarich
    But not for too long so you foul a plug:s
  8. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Your bike has a small 5 point plastic knob on the bottom of the throttle housing. It is a friction adjustment, and can be tightened to hold the throttle in any position. NOT recommended to use as cruise control replacement.
  9. ironmark
    ironmark Junior Member
    754
    5
    On my 08 FLTR the cruise won't lock over 80mph.
  10. dbmg
    dbmg Guest
    After starting you should only warm up a minute or two anyways. Not sure why longer warm up needed.
