Cranks / no start
Discussion in 'Electrical' started by Babe, Dec 29, 2012.
  1. Babe
    Babe Member
    My 2001 duece with 44,000 miles has been starting fine about once a week, have not rode in 2 months. started up rode half a block shut it off for 1 hour. went to go for a ride, cranks but wont start.had Power commander installed 1 year ago, all was fine until now. checked fuses by eye, on My way now to get My volt meter. engine light comes on, fuel pump comes on. Any suggestions ? any and all Help appreciated. Thank You
  2. Had similiar problems with mine. Replaced crank sensor but I dont think that was the problem. Finally replaced battery and seems to work, not sure yet. Battery tested fair but after jumping off truck it started. I am hoping that battery may have had a weak cell. Check out tips for checking cps, it worked for me. Good luck
  3. Bodeen
    4,643
    73
    221
    Does the fuel pump shut off after a period of time following turning on the key? Does it continue to run?
  4. Hoople
    Hoople Account Removed
    7,198
    34
    I would unplug the Power Commander and temporally go back to stock wiring. Try using this PDF to pull any historical codes. This procedure should work for your bike also. Use meter to check fuses because sometimes they can fool you.
  5. Hoople
    7,198
    34
    This goes back to the 03 SE Deuce. If a fresh battery does fix the no spark issue problem, I would compare the voltage directly across the battery & battery voltage at the primary of the coil (Yel/Green, terminal A) during cranking. Those numbers should be the same or very very close to each other.
    If those numbers are far apart, that would explain why a new battery would fix a no spark issue.
    Also if your plugs were totally shot or are gaped at some unreal distance, I guess it would also be possible that during times when "every volt counts", it may not have spark.
    I have never seen it, but I guess it could be possible. I would lean more on a difference between battery post & coil voltage.
