crank twisted
Discussion in 'Engine, Fuel and Exhaust' started by AliveAgain, Aug 14, 2011.
  1. AliveAgain
    AliveAgain Member
    47
    The bike was making a racket even before installing the hydraulic conversion and cams so I brought it to the dealer. They said the oil press. was lower then where it should have been and probably need a tear down. Here is what I found.
    [​IMG]
    marks on the end of the shaft
    [​IMG]
    aw what the heck
    [​IMG]
    [​IMG]
    this was the trans. shaft
    [​IMG]
    I'll take it apart tomorrow and next weekend ,send it out.
    I'm wondering if putting it on the dyno making a lot of pulls to get a map contributed to this. I'm not trying to blame the tuner , just a heads up.
  2. TripleJ
    TripleJ Senior Member
    1,081
    8
    Not trying to add salt to the wound but this is exactly why you will never see one of my bikes on a Dyno. Unless you need to squeeze every last ounce of power from your scoot a Dyno-Tune is doing more wear and tear than is necessary for a daily driver. Racing, well that a different ballgame altogether..
    Hope you get her back together and can enjoy the ride soon.
  3. glider
    50
    I have to agree about not subjecting any bike to a dyno. Sure IF the operator knows what they are doing they can get a few more HP out of the engine but it takes it's toll on the engine too.
  4. AliveAgain
    AliveAgain Member
    47
    I had it on the dyno because it smelled rich and wanted the gas mileage. We just did a runout and it was .003 so I guess the noise wasn't where I thought it would be. A little puzzled now.
