Sheepdogmarine
Now that I have decided to keep my bike, I am looking at several upgrades.
I am looking at an engine kit that has gear drive cams. I am pretty sure it may be easier to install the conversion kit and run a roller chain, but there are more cam choices with the gear drive.
My question is this? How far do I have to disassemble the engine to check crank runout? Looks like I can remove the right side cover and maybe the oil pump and then check it. If it checks good, then the gear drive is the way for me. I don't mind doing some work to see if a gear drive is doable or not. I know the runout cannot exceed .002". I don't mind being down a couple days, just don't want it to be a couple weeks and then have to send back parts and change plans.
So what is the easiest, quickest way to check runout?
Thanks,
Eric
Thanks,
Eric
