ausibatla
G'day fella's,
Haven't been in touch for a while 'cause everything's been OK but now need some advice.
My bike is a 1988 softail Springer (85th anniversary model) with a 1990 1340 motor. Work has been done on it and I have mentioned this before.
Both cylinders have 200PSI which means around 10:1 compression, it has a 42mm Mikuni Flat Slide carby and a free breathing Screaming Eagle Air filter. It also has an Ultima Digital single fire Ignition system with VOES set at 6.0 in/hg. Knowing this I took it in to get it dyno tuned and it came up with just 54HP. The mechanic said the Vance & Hines short shots were killing it and what I needed was a set of Freedom Performance Declaration Turnouts.
So yesterday I had him fit a new set of Turnouts and do another dyno run.
I got 56.47 HP out of it. Now he claims that it must be the cam because it runs real smooth and not like it would if it had a decent cam.
With the work that's been done I would have thought I would get at least another 10-12 HP out of it.
Do you guys think it needs a cam to bring out the ponies and if so what grind or make of cam would you suggest.
I have a picture of the dyno curve and settings but don't know how to upload it.
Cheers,
:cheers:AUSTRALIA
Have attempted to upload copies of dyno run info.
IT WORKED.
http://i571.photobucket.com/albums/ss156/ausibatla/Harley%20Springer/Dyno%20run%20info_zpsmmniutq7.jpg
Cheers,
:cheers:AUSTRALIA
Cheers,
:cheers:AUSTRALIA
IT WORKED.
Cheers,
:cheers:AUSTRALIA
