Picked up the Trike 3 days ago after haveing it checked out.
I have changed the primary fluid 5 times as I found slivers on the drain plug.
The dealer said they tightened the compensator and that should fix the problem.( sounded as if you were takeing off in 2nd gear).
Left the shop and returned as it is the same, doesn't happen every time but did in their lot.
The srevice manager rode around and said he needed to get with his factory rep. yesterday.
The factory guy said nothing is wrong as it is like all the other ones. Although
he told them there is a,(SEMI PROBLEMATIC CONCERN), on the Trikes. I am sitting here looking at a Semi problematic trike with nothing to ride, any ideas
