Cometic Rocker Box Gasket install
Discussion in 'Engine, Fuel and Exhaust' started by ConvertRider, May 23, 2011.
  1. ConvertRider
    ConvertRider Member
    10
    I am in the process in replacing the rocker box gaskets because one of the lower one piece gaskets was leaking. I got cometic gaskets which are metal and one piece. I do not know which side to place up when installing. Should I put the side up where I can read the imprint of the part number? I do not want to have to do this job twice because I put them in upside down.
    Thanks
  2. Jack Klarich
    Cometic Gasket, Inc. or call J P 800 number:s
  3. fin_676
    5,788
    153
    287
    I have used the hd metal lower rocker gaskets on an evo engine or 2 and had the part numbers up i haven't yet had any trouble with them
  4. ConvertRider
    ConvertRider Member
    10
    I called Cometic technical service line and the guy looked up the drawing on CAD and told me that it did not matter which way they were put in as long as the holes lined up. I'm going with the part numbers up.
