codes up after working on bike.
Discussion in 'Touring Models' started by ultrat, May 8, 2010.
  1. ultrat
    ultrat Senior Member Contributor
    1,315
    After removing outer fairing & doing the wire cut movement for having spots on w/ high beams on same time. I also installed a plug for future GPS, from the unused hot & ground by headlight plug. when reassembled bike to check my work. i noticed my engine lite relighting telling me i had codes. so i checked. i got a P1511 & P2101. Throttle actuator control power management failure of throttle control actuator & Throttle actuator control motor circuit range/performance error' I was able to clear codes & what i did worked i now can turn on hi w/ spots. Question is has this happened to anyone else after doing this electrical change. & should i worry i did not disconnect battery. i did pull ign key chrome knob.
    Wait and see if they return before loosing any sleep over it.:D
  3. ewiltgen
    ewiltgen Member
    89
  4. ultrat
    1,315
    Ill be keeping an eye on engine light. went for a ride codes did not reappear. just wondering w/ caused my codes. 1 cut orange wire, i did turn my ign switch w/ screwdriver in several directions to align key shaft lower & upper paddles when putting back together.
