Codes P0572, C1094 & C1214
Discussion in 'Electrical' started by nascar7613, Sep 19, 2016.
  1. nascar7613
    nascar7613 Active Member
    241
    38
    5
    2011 Ultra. Codes P0572, C1094 & C1214 all coming on. The brake light stays on all the time. Disconnected wire from rear brake light switch and brake light still on. Checked the fuses, all good. Something in the brake light wiring? Anyone experienced this before?
    Also getting U1040
  2. Harttoo
    Harttoo Senior Member
    2,092
    140
    C1094 is front brake switch always on.Check front brake switch.
  3. Jeff Klarich
    4,787
    103
    484
    Have you done any work around the switch lately? Maybe a pinched or wire shorting out? Here are the codes for your scoot.
    .B0562-Battery voltage low
    B0563-Battery voltage high
    B1004-Fuel level sending unit low
    B1005-Fuel level sending unit high/open
    B1006-Accessory line overvoltage
    B1007-Ignition line overvoltage
    B1008-Trip odometer reset switch closed
    B1121-Left turn output fault
    B1122-Right turn output fault
    B1123-Left turn signal short to ground
    B1124-Right turn signal short to ground
    B1125-Left turn signal short to voltage
    B1126-Right turn signal short to voltage
    B1131-Alarm output low
    B1132-Alarm output high
    B1134-Starter relay output high
    B1135-Accelerometer fault
    B1136-Accelerometer tip-over self test fault
    B1141-Ignition switch open/low
    B1142-Internal fault
    B1143-Security antenna short to ground
    B1144-Security antenna short to battery
    B1145-Security antenna open
    B1151-Sidecar BAS short to ground
    B1152-Sidecar BAS short to battery
    B1153-Sidecar BAS out of range
    B1154-Clutch switch short to ground
    B1155-Neutral switch short to ground
    C0562-System voltage low
    C0563-System voltage high
    C1014-ECU internal solid state relay fault
    C1017-Pump motor power circuit open fault
    C1018-Pump motor ground high resistance fault
    C1021-Front wheel speed sensor always equals
    C1023-Rear wheel speed sensor always equals
    C1025-Front wheel speed sensor signal intermittent
    C1027-Rear wheel speed sensor signal intermittent
    C1032-Front wheel speed sensor circuit open/shorted
    C1034-Rear wheel speed sensor circuit open/shorted
    C1042-Pump motor open
    C1043-Pump motor stalled
    C1055-ECU internal fault
    C1056-ECU internal fault solid state relay shorted ON
    C1057-ECU internal fault solid state relay shorted to ground
    C1061-ECU internal fault front apply solenoid
    C1062-ECU internal fault front release solenoid
    C1065-ECU internal fault rear apply solenoid
    C1066-ECU internal fault rear release solenoid
    C1094-Front brake switch always on
    C1095-Front brake switch open
    C1118-ECU internal fault front apply solenoid correlation
    C1121-ECU internal fault rear apply solenoid correlation
    C1151-Front wheel ABS release too long
    C1153-Rear wheel ABS release too long
    C1158-Calibration programming required
    C1206-Front wheel speed sensor frequency out of range
    C1208-Rear wheel speed sensor frequency out of range
    C1212-Front or rear brake not applied with decel
    C1214-Rear brake switch always on
    P0031-02 heater low/open
    P0032-02 heater high/shorted
    P0106-MAP sensor rate of range error
    P0107-MAP sensor low/open
    P0108-MAP sensor high
    P0112-IAT sensor low voltage
    P0113-IAT sensor voltage high/open
    P0117-ET sensor voltage low
    P0118-ET sensor voltage high/open
    P0120-Throttle position sensor 1 range error
    P0122-TP sensor low/open
    P0123-TP sensor high
    P0131-Front 02 sensor low (lean)
    P0132-Front 02 sensor high (rich)
    P0134-Front 02 sensor open/not responding
    P0151-Rear 02 sensor low (lean)
    P0152-Rear 02 sensor high (rich)
    P0154-Rear 02 sensor open/not responding
    P0220-Throttle position sensor 2 range error
    P0222-Throttle position sensor 2 low/open
    P0223-Throttle position sensor 2 high
    P0261-Front injector low/open
    P0262-Front injector high
    P0263-Rear injector low/open
    P0264-Rear injector high
    P0373-CKP sensor intermittent
    P0374-CKP sensor synch error
    P0444-Purge control low/open
    P0445-Purge control high
    P0501-VSS low
    P0502-VSS high/open
    P0505-Loss of idle speed control
    P0562-Battery voltage low
    P0563-Battery voltage high
    P0572-Brake switch low
    P0577-Cruise control input high
    P0602-Calibration memory error
    P0603-ECM EEPROM error
    P0604-RAM failure
    P0605-ECM flash error
    P0607-Converter error
    P0641-5V ref 1 out of range
    P0651-5V ref 2 out of range
    P0661-Intake solenoid low/open
    P0662-Intake solenoid high/shorted
    P1001-System relay coil low/open
    P1002-System relay coil high/shorted
    P1003-System relay contacts open
    P1004-System relay contacts closed
    P1009-Incorrect password
    P1010-Missing password
    P1270-Twistgrip position sensor 2 A/D validation error
    P1351-Front ignition coil low/open
    P1352-Front ignition coil high/shorted
    P1353-Front cylinder no combustion
    P1354-Rear ignition coil low/open
    P1355-Rear ignition coil high/shorted
    P1356-Rear cylinder no combustion
    P1357-Intermittent secondary front
    P1358-Intermittent secondary rear
    P1475-Exhaust position actuation error
    P1477-Exhaust actuator low/open
    P1478-Exhaust actuator high/shorted
    P1501-JSS low
    P1502-JSS high
    P1510-Throttle actuator control limited performance
    P1511-Throttle actuator limited power management mode
    P1512-Throttle actuator control forced idle mode
    P1514-Throttle actuator control system airflow fault
    P1600-TCA module internal fault
    P1655-ACR solenoid low
    P1656-ACR solenoid high
    P2100-Throttle actuator control motor circuit open
    P2101-Throttle actuator control motor circuit range error
    P2102-Throttle actuator control motor circuit low
    P2103-Throttle actuator control motor circuit high
    P2105-Throttle actuator control system forced engine shutdown
    P2107-Throttle actuator control module processor
    P2119-Throttle actuator control system throttle return error
    P2122-Twistgrip position sensor 1 low/open
    P2123-Twistgrip position sensor 1 high
    P2127-Twistgrip position sensor 2 low/open
    P2128-Twistgrip position sensor 2 high
    P2135-Throttle position sensor correlation error
    P2138-Twistgrip position sensor correlation error
    P2176-Throttle actuator control system closed position not learned
    U1016-Loss of ECM serial data
    U1040-Loss of ABS serial data
    U1064-Los of TSM/TSSM/HFSM serial data
    U1097-Loss of speedometer serial data
    U1255-Missing response at module
    U1300-Serial data low
    U1301-Serial data high/open
    Radio Diagnostics
    The radio DTC are retrieved through the radio and displayed on the radio display.
    1. Press eject button to remove CD from unit
    2. While pressing and holding any two (2) softkeys (buttons 1-6) , turn the ignition switch "ON" until radio diagnostic display appears
    B2006-Radio switch stuck or open
    B2007-Handlebar switch high/shorted
    B2008-Handlebar switch low/shorted
    B2009-Handlebar switch stuck or open
    B2010-Passenger switch high/shorted
    B2011-Passenger switch low/shorted
    B2012-Passenger switch stuck or open
    B2016-Front speakers shorted
    B2017-Front speakers open
    B2018-Front speakers shorted to ground
    B2019-Front speakers shorted to battery
    B2020-Rear speakers shorted
    B2021-Rear speakers open
    B2022-Rear speakers shorted to ground
    B2023-Rear speakers shorted to battery
    ATS=Air Temp Sensor
    BAS=Bank Angle Sensor
    CCM=Cruise Control Module
    CKP=Crank Position Sensor
    ECM=Electronic Control Module
    ECU=Electronics Control Unit
    EFI=Electronic Fuel Injection
    JSS=Jiffy Stand Sensor
    MAP=Manifold Absolute Pressure sensor
    HFSM=Hands Free Security Module
    TSM/TSSM=Turn Signal/Turn Signal Security Module
    VSS=Vehicle Speed Sensor
    WSS=Wheel Speed Sensor
    ACR=Automatic Compression Release
    TCA=Throttle Control Actuator
    IAT=Intake Air Temp sensor
    ET=Engine Temp sensor
    IAT=Intake Air Temp Sensor
  4. Jack Klarich
    DTC U1040 indicates that the ABS module is not capable
    of sending its state of health message. ( and this makes the ABS Light not flash ) check connections on the Module ...all fuses ...
    Change the brake light switch down by the brake pedal
    Make sure the front hand brake switch is not broken, Have yo had the rs switch half off recent? Did you put a piece of cardboard in the switch? If not you may have broken that switch, not fun to replace
    There is a new brake light switch kit out I forgot the part number it comes with a new wire pig tail
    I bet your cruise does not work?
  5. nascar7613
    241
    38
    5
    I found the problem! The front brake light switch spring clip moved and let the switch move back into the housing. Fished the clip out and bent it to make it tighter, got the switch all the way back in it's hole, put the clip back in and all seems well. Thank you Jack for your attention to my problem!
  6. Jack Klarich
    You are welcome, good find ;)
