Code P0562
Discussion in 'Electrical' started by 2007electraglide, Jun 8, 2015.
  1. 2007electraglide
    2007electraglide Member
    5
    New guy here, but been riding Harleys over 40 years. 2007 Electraglide standard started acting up. It would die when clutch pulled in at idle. Turn signals would not cancel themselves. I replaced speed sensor and all seemed fine for about 10 miles, the engine and battery lights came on and battery drained. Checked and tightened battery cables and charged battery.Turn signals now working. Code still flashes on P code, P0562. I think it may be the stator. My question is, are there any other or simpler things to check?
  2. Jeff Klarich
    4,844
    103
    496
    That code is, battery low voltage EFI, How old is your battery? yes the stator could be going south on you. First thing I'd do is a load test on the battery to see if it's good and charging.
  3. 2007electraglide
    5
    Thanks for your response. Battery is on charger for several hours now and is taking charge, bike starts and shows engine light. I had a stator go bad on a 99 Road King and the engine would die, jump started it several times to get me home. My 07 volt gauge went from 14 to 10. By the time I drove the 10 miles home it read 8. Shut it of and that was it, battery was dead.
  4. Jeff Klarich
    4,844
    103
    496
    It's a process of elimination, start with load test on the battery and making sure all connections are clean and tight. A test of the voltage regulator might be another area to check.
  5. stray dog
    stray dog Junior Member
    443
    Hopefully just a bad battery, how old is it? Like Jeff said, have it load tested. Just because it takes a charge doesn't mean its good.
    Also see link below:
    Harley Davidson Forums
  6. 2007electraglide
    5
    Still stumped. Battery tested good.12.58V. 460CCA. Can it be a bad ground or loose wire? Looks like I'll be taking it to a shop.
  7. Jeff Klarich
    4,844
    103
    496
    Make sure when you check connections you check the cables on the starter too. That cable is the most unchecked when issues arise. You may also want to check the voltage regulator.
  8. 2007electraglide
    5
    Checked, just had starter out to replace speed sensor. I hate electrical problems.
  9. stray dog
    443
    Did you actually load test the battery or just check it with a VOM or DMM. Most auto parts stores will check it for free.
    Did you check the charging system, or doesn't it start.
  10. Jeff Klarich
    4,844
    103
    496
    When running what does the voltmeter read? and does it hold steady?
