clutch/tran issue after oil change
Discussion in 'Transmission' started by hogsolo, Mar 28, 2010.
  1. hogsolo
    hogsolo Member
    17
    T MAY JUST BE A COINCIDENCE, BUT...
    I changed my engine oil mysef this time around ( 08 Nightster) with recommended 20-50w. Whatever oil was in there before was whatever standard oil the dealers had put in.
    Now I have issues getting into neutral, sometiems it goes past 1st->2nd or 2nd->1st, or sometimes I cant shift at all. If I move the bike a bit I can then get into N.
    Also, after this oil change, the motor sounds very different. I don'nt think there's anything broken, but can a heavier weight oil cause clutch/shifting problems?
    thanks
  2. Bud White
    3,270
    now you only changed the engine oil right? would have nothing to do with clutch or tanns.. or did you change it to ?
  3. Jack Klarich
    What did you drain, the oil or the primary
  4. NEWHD74FAN
    8,191
    98
    19
    Hogsolo, welcome to the HDForum and your first post. May want to retrace your steps changing the oil or the tranny on your Nightster (if similar to Sportster I believe)...look into this extract from the Self Help Tips section:
    http://www.hdtimeline.com/archive/index.php/t-3132.html
    Engine Oil Change: FYI, may want to fabricate an oil filter drainage try to prevent spilling all over the engine motor mount and garage floor.
    http://www.linson.us/harleydavidson/sportsters/bertshowto/berts_how_tos_oilchange.htm
    Tranny, Clutch, Primary Case:
    http://www.harleydavidsonmaintenance.com/sportster-transmission-oil.html
  5. lowrider13
    lowrider13 Active Member
    113
    Did you change the tranny instead of engine. On my dyna you think where the oil plug should be is actualy the tranny plug.Do you have a manual?
  6. hogsolo
    hogsolo Member
    17
    It was the engine oil I changed. There's a drain plug/tube under the motor, it's pretty straightforward.
    I THOUGHT the Nightster had a wet clutch that fed off the engine oil, but I could be incorrect.
  7. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    YOU ARE! WRONG that is.
    get your manual out and it will give you the answers READ IT FIRST before you do the EASY TO DO THINGS...
    LOOK under self help and it will ALSO answer most of the questions you have.
    WHEN YOU SAY,"It's pretty straightforward" BE CAREFUL cause it MAY NOT BE THAT WAY!!!
    There are MORE than one drain plug on my bike,,,UNDER the MOTOR.
    welcome........... read, ask and learn.
  8. dbinbc
    dbinbc Active Member
    136
    The Nightster has 2 oils just like Hobbit said. The engine is stand alone with its own oil that is stored up in the tank by the right side of the seat and is drained out underneath just in front of the back wheel via the little rubber hose. The primary and tranny share 1 qt of oil (preferably the Fromula +) and it is drained out the bottom of the primary case through the bolt drain hole.
  9. NEWHD74FAN
    8,191
    98
    19
    Hogsolo, if its like the Sportster, you unclipped the oil drain hose and removed the end stopper and drained the Engine oil only.
    You did not touch either the "hex nut/allen" primary chain adjuster, or the "trans/primary/clutch drain plug which tread into the tranny/case housing...correct? :coffee
  10. glider
    50
