clutch cable
Discussion in 'Softail Models' started by PaPa T, Sep 25, 2012.
  1. PaPa T
    PaPa T Active Member
    124
    Long story short dealer did some work and screwed up clutch cable. They replaced with no questions. Now it is at the last couple of threads on adjuster to get 1/16 to 1/8 play at lever. Do I need to readjust my clutch to gain more room. It is the right cable. 09 Heritage with 15,000 miles on it clutch was adjusted about 3000 miles ago. Also has any body used lucas gear oil and what did you think of it.
    Thanks
    PaPa T
    Nam Vet
  2. tourbox
    tourbox Senior Member
    1,888
    168
    You may need to adjust the clutch in the primary. Go to the Self Help,top of page, there will be a drop down. Click on Transmissions,Clutch and Primary. Scroll down to # 88 & # 92 they will tell 2 different ways to adjust it.I've used both and like the Easy method better.
    tourbox
  3. Jack Klarich
