Clutch cable
Discussion in 'General Harley Davidson Topic' started by mat 60, Sep 19, 2011.
  1. mat 60
    mat 60 Senior Member
    1,237
    5
    My bars came in today:D and while adjusting my new clutch cable when I release the clutch lever it doesn't go all the way back out...Im wondering if there is a problem?...
    50
    Not knowing what you did so far, maybe this will help out. Are you sure the cable is correct for the application?
    Harley Davidson Community
  3. mat 60
    1,237
    5
    The cable came from hill country along with bars new clutch lever...Im pretty shore of my install....Question ...when you pull in the clutch doesn't it push on a rod with fins on it ....When I had the cover off is that rod going to turn freely?
  4. glider
    50
    Which cover are you talking about? Which side, probably the right side sitting on the bike?
  5. mat 60
    1,237
    5
    yes the right side cover that I had to take off to change the cable.....Do I also need to adjust cluch when I change cable because all I did is adjust cable itself
  6. glider
    50
    If it's the right length cable, you shouldn't have to adjust the clutch, however it wouldn't hurt to do it anyway.
    Are you sure you got all 3 balls into the ramp when you changed the cable? Squeeze the clutch lever 3 times before adjusting anything to reseat the balls in the ramp too.
  7. mat 60
    1,237
    5
    Ok.....Ill do it tomorrow and see if that helps....Thanks...Sorry that I dont do well explaining myself...:)
  8. glider
    50
    You do better than some:D
  9. mat 60
    1,237
    5
    Im going out to the shop for a while...:)..Thanks
  10. mat 60
    1,237
    5
    Well, Well,Well........After I adjusted the clutch and checked the ramp and balls to no luck:).I took the clutch Handel off and installed the Handel back on without the cable only to find out the plastic piece was to tight...All I had to do is sand it down a little..Oh god help me..:newsmile100:..I no you guys can tell that I havent worked on bikes.....
