Streetglider08
I'm getting alot of slop in my clutch lever and it was shifting a little hard today. So I opened up my manual and looked up clutch adjustment. Got slack in the cable and popped the clutch inspection cover and loosened up the jam nut, adjusted the clutch screw, tights the jam nut and then took the slack out of the cable. Put the cover back on and have great lever tension with almost no slack. Now when I pull out in first gear the clutch doesn't grab untill it's almost totally out. I feel that it's not right or am I just not used to it. Not sure, it's all new to me. only thing I'm thinking is I should not have touched the clutch adjustment screw and just should have taken the slack out with the cable adjuster but I didn't realize it untill it was too late. Bike has 6k on it and the clutch prob should not have been adjusted, just the cable. Is it too late to put the clutch adjustment screw back where it was? And start over?
