Cleaning mag wheels
Discussion in 'Wheels' started by billkater, Aug 20, 2008.
  1. billkater
    billkater New Member
    4
    I have just purchased a 2002 883 Hugger. It has mag wheels on it. What is the best way to get these clean? They are black with grim and brake dust.
    Thanks
    Bill
    50
    S100 does a good job and should be available at the dealers. Make sure to rinse it off good. Simple green will work good too.
  3. Vibratinharley
    Vibratinharley Junior Member
    428
    Hey, what about PLEDGE? :D
  4. glider
    50
    That's AFTER the cleaning:D
    Repels the dirt.
  5. Crazyfrog
    Crazyfrog Active Member
    367
    If the aluminum is really dirty, (not the black part), I use Blue Magic. Cleans cast aluminum to almost a chrome shine with just a little elbow grease.
    You can get it at most auto parts stores.
  6. AugMan
    AugMan Account Removed
    32
    I use neverdull by eagle one on my mags and it seems to work well. after a scrub with that a nice coat of mother's mag polish
  7. vpats
    vpats Member
    54
    One big YES on the Mothers aluminum/chrome polish. I also invested in a bike lift and an empty 5 gallon bucket, turn the bucket upside down to sit on and put the bike on the lift ... makes cleaning the wheels a breeze.
    If you have some real nasty spots I've also used SOS pads, 1000 & 2000 grit wet/dry sandpaper, to use on the bare aluminum, followed with the Mothers .. really works wonders.
  8. soulshaker
    soulshaker Member
    57
    6
    I have used a scotch brite disc on a dremal tool. If the aluminum has started to pit use a med. scotch-brite and going over finishing with a fine pad. Finish up w/ jewelers rouge on a buffing pad, or never dull will help.
